DIMMARKOVERRIDES command
Adds or removes underline to dimensions with overridden dimtext.
Adds or removes underline to dimensions with overridden dimtext by making database modifications.
Select dimensions
Select dimensions with overridden dimension text. When all desired dimensions are selected, press Enter.
Note: To mark dimensions with overridden dimtext without database modification, set the DIMMARKTYPE system variable value to 1 or 2.
Options within the command
Once all desired entities are selected, two options are available:
Mark
Underlines the overridden text for the selected dimensions.
Unmark
Removes the overridden text underline for the selected dimensions.
