DIMREASSOCIATE command
Reassociates or associates dimensions to entities or points on entities.
Icon:
Selected dimension entities highlight one by one with prompts to specify association points or entities for the currently highlighted dimension entity.
Note: A marker displays at the current position of the edited dimension point:
indicates a non-associated dimension point. -
indicates an associated dimension point.
Methods
The DIMREASSOCIATE command can be used in six different ways:
- Linear (rotated and aligned): specify an entity or two lines.
- Diameter: select arc, circle or polyline arc.
- Radius: select arc, circle or polyline arc.
- Angular: select 2 lines or 3 points, an Arc or a circle.
- Ordinate: specify feature location.
- Leader: specify leader association point.
Options
- Disassociated
- Prompts to reassociate ALL disassociated dimension entities in the drawing. All disassociated dimensions highlight one by one.
