DIMTEDIT command
Changes the position of dimension text.
Icon:
Alias: DIMTED
Allows you to change the position and angle of the text within a dimension entity.
Method
This command offers four methods to change the position of dimension text.
- Rotate the dimension text.
- Move the dimension text to the left.
- Move the dimension text to the right.
- Center the dimension text.
Options within the command
- Angle
- Rotates the dimension text from the original dimension text position (1) to the rotated dimension text position (2).
- Left
- Moves the dimension text next to the left extension line of the dimension, depending on the original positioning of the dimension.
- Center
- Centers the dimension text between the two extension lines of the dimension.
- Right
- Moves the dimension text next to the right extension line of the dimension, depending on the original positioning of the dimension.
- REstore
- Resets the rotation angle of the dimension text to 0 degrees and does not change repositioned dimension text.
