DMAUDITALL command
Analyzes and repairs errors in drawings inserted as external references
It is a powerful tool to analyze and automatically fix problems in 3D geometry supported by ACIS kernel (3D solids, surfaces).
Note: It is recommended to run DMAUDITALL whenever 3D geometry is imported.
Method
There are two methods to audit the drawing:
- Check problems.
- Fix problems.
Options within the command
- Check
- Checks the 3D geometry in the drawing for errors without fixing them.
- Fix
- Repairs errors.
- Back
- Returns to the main prompt of the command.
- report Panel
- Redirects the output of the command to the Report panel.
Note: Depending on the value of REPORTPANELMODE variable, it might be necessary to click on the red exclamation mark in the lower right corner to see more details in the Report panel.
- copy to File
- Reports the output of the command in a file.
- audit Level
- Sets the strictness of the check.
- Low
- Runs basic analysis (for example, catching common fatal topology errors).
- High
- Goes deep (for example, catching self-intersections in solid bodies).
- Medium
- This is the default level.
- Coincident faces
- Checks and fixes coincident faces. Requires audit level set to High.
