DMCONCENTRIC3D command
Applies a concentric constraint between two circular subentities of 3D entities.
Icon:
Method
The concentric constraint could be applied between any two circular surfaces or circular edges of a 3D entities (cylindrical (circular or elliptical), spherical or conical surfaces and their edges) or between a subentity of a 3D entity and a 2D circular entity.
Select the two circular subentities between which the concentric constraint will be applied. Press the TAB key to select obscured geometry.
Options within the command
- WOrld
- Allows you to select the WCS subentity as an argument.
- BLock
- Allows you to choose, as an argument, the subentity of the coordinate system of the block.
