DMCOPYFACES command
Copies a feature from a 3D solid.
Icon:
Copies a set of 3D solid faces forming a protrusion or depression feature, such as holes, pockets, extrusions, ribs, and their combinations within the same 3D solid or from one 3D solid to another.
Options within the command
- Select entities
- Select all faces of the entire feature.
- Base point
- Specify the base point.
- Insertion point
- Allows you to select an insertion point.
- Rotate
- Rotates the faces around the Z axis of the UCS.
- mUltiple
- Insert multiple copies of a feature.
- MOde
- Toggles between various cutting options.
- Placement Face
- Cuts the copied feature so that it suits the placement face.
- Select Faces
- Cuts the copied feature so that it suits the selected face.
- No Cut
- Does not cut the copied feature.
