DMDEFORMCURVE command
Deforms 3D solids or surfaces by replacing their edges with given curves.
Icon:
Deforms one or more connected faces of a 3D solid or a surface by replacing their edges with given curves.
Select the edges that will be replaced with the target curves to get the new 3d solid or surface.
Options within the command
add Faces
Allows to select additional faces, other than the faces adjacent to selected edges, to deform.
Multiple edges
Allows the deformation of a chain of edges to a single target curve.
