DMPUSHPULL command
Adds or removes volume from a solid by moving highlighted faces.
Icon:
Adds volumes to or removes volume from a solid using the cursor movement or direct distance input. You can use this command to edit any face of a 3D solid or a surface. You can select more faces or detected boundaries. Press Enter to complete the selection set.
Note:
- The volume is automatically adjusted to the specified length for selected planar faces or to the specified radius for selected cylindrical, spherical, or toroidal faces.
- Plies of multiply compositions are selectable if the Select Faces of the SELECTIONMODES system variable is set.
The selected geometry moves dynamically. Using the Manipulator you can do one of the following:
- You can press the TAB key to select a different reference face. All faces which are parallel to the face being push/pulled are recognized, beginning with the first ones. Press and hold the SHIFT key when pressing the TAB key to cycle reference faces in reverse order. To select a reference face on a different solid, move the cursor over that face, then hit the TAB key. The selected face is highlighted.
- Click a point in the model.
- Type a value in the dynamic distance field.
- Move the cursor to adjust the value in the dynamic distance field. You can optionally zoom in/out to set the snap increment size of the ruler.
Options within the command
- Enable subtract
- Solids being push/pulled are subtracted from other 3D solids they intersect.
- Disable subtract
- Solids being push/pulled are not subtracted from other 3D solids they intersect.
