DMTANGENT3D command
Applies a tangent constraint between circular subentities of 3D entities.
Icon:
Applies a tangent constraint between a face and a curved surface of different 3D entities or a surface and WCS reference coordinate system or a surface and a reference coordinate system of a block reference. Press the TAB key to select obscured geometry.
Options within the command
- WOrld
- Allows you to select the WCS subentity as an argument.
- BLock
- Allows you to choose as an argument the subentity of the coordinate system of the block.
