DMTHREAD command
Creates threads on cylindrical faces, which are represented according to drafting standards in drawing views.
Icon:
Creates a thread feature in the model that is represented according to drafting standards in drawing views or section view created with VIEWBASE and VIEWSECTION commands.
Note: This command can be entered transparently during commands with ‘dmthread.
Method
Selecting a cylindrical face and specifying the pitch and length values a thread feature will be created, that will be represented according to drawing standards in drawing views. With VIEWUPDATE command the changes will be applied in the drawing views.
Thread features display in the Mechanical browser , where you can edit the thread parameters.
Note: Male and female thread types are supported.
Note: This command operates only in Model Space.
Below you can see the result of VIEWBASE and VIEWSECTION commands.
- Length
 - Diameter
