DWFOUT command
DWFOUT command
Saves the drawing in DWF and other formats.
Saves the drawing in DWF and other formats (short for "drawing Web format output"). DWFOUT is an alias for the EXPORT command.
Note: DWF files can be viewed with the DesignReview software, available free from www.autodesk.com/designreview.
Related commands
  • EXPORT command
  • DXFOUT command
Related information
  • File Types Dictionary
  • Standard save file dialog box
