DWGCOMPARECLOSE command
Closes the Compare panel.
Closes the Compare panel to hide it from the current workspace. If the Compare panel is stacked when you close it, the Compare tab or icon is removed from the stack.
Related commands
  • DWGCOMPARE command
  • DWGCOMPAREOPEN command
Related information
  • Compare panel
  • Panels
  • Workspaces
Octave
