EDITTIME command (Express Tools)
Tracks the active editing duration for a drawing.
Method
You can turn On and Off the timer, or reset it. The timing is suspended after a specified period of inactivity.
Options within the command
Reset
Allows you to reset the timer to zero. Timing is restarted automatically if the timer is running.
Timeout
Allows you to specify the period of inactivity, in minutes. The timer automatically suspends timing when the timeout period expires.
On
Allows you to start or resume the timer.
Off
Allows you to stop the timer.
