EDITTIME command (Express Tools)
Tracks the active editing duration for a drawing.
Method
You can turn On and Off the timer, or reset it. The timing is suspended after a specified period of inactivity.
Options within the command
- Reset
- Allows you to reset the timer to zero. Timing is restarted automatically if the timer is running.
- Timeout
- Allows you to specify the period of inactivity, in minutes. The timer automatically suspends timing when the timeout period expires.
- On
- Allows you to start or resume the timer.
- Off
- Allows you to stop the timer.
