EXOFFSET command (Express Tools)
Offsets the selected entities.
Icon:
Method
Enter the offset distance and select the entities to offset.
Options within the command
- Through
 - Offsets the selected entity through a specified point.
- Multiple
 - Offsets the selected entity multiple times.
- Options
 - Lists the values of Distance, Layer and Gaptype in the command line.Note: The Gaptype is controlled by the OFFSETGAPTYPE system variable.
