EXPORTLAYOUT command
Opens the Export layout to drawing dialog box.
Opens the Export layout to drawing dialog box to save data from the current drawing to a .dwg file. The current layout specifies what data to include in the drawing. After the drawing is created, a BricsCAD dialog box allows you to choose if you want to open the new drawing.
