EXTRACTBLOCKS command
Extracts blocks to individual files.
Method
This command extracts a block instance from a drawing, creating a separate DWG file in a user-specified location.
After selecting a block to extract, the Select Folder dialog box displays to choose the location for the new created DWG file.
Related commands
  • BLOCKTOXREF command
  • -BLOCKTOXREF command
  • BMEXTERNALIZE command
  • CREATELIBRARYBLOCK command
  • WBLOCK command
