FBXEXPORT command
Exports 3D entities in the current drawing to FBX format.
Note: If you wish to export 2D entities, you must first give
them a thickness.
Method
There are two methods to export to FBX format:
- Export all visible entities.
- Export only the selected entities.
Options within the command
- Selected
- Select the entities to be exported.
- Visible
- Exports all visible entities.
- Select
- Prompts to select among entities, lights, cameras and materials.
- All
- Exports all entity types.
- Embedded
- Includes the texture files into the FBX file.
- Reference to file
- Adds a reference link in the FBX file to the location of the texture files.
- Copy to file
- Copies the texture files to the destination folder, separately from the FBX file.
- Enter path to export fbx file:
- Specify the path to the folder in which to place the FBX file, or press Enter key to accept the path provided.
