FILEOPEN command
Opens files from the Command line.
Opens drawing (DWG), template (DWT), and interchange (DXF) files from the command line, replacing the current drawing.
Options within the command
Save the changes to drawing file?
Specifies whether the current drawing should be saved or not.
Open Drawing
Type the name of the drawing, including path.
Note: Enter ~ to display the Open Drawing dialog box.
