FLATTEN command
Flattens 2D and 3D entities.
Icon:
Flattens 2D and 3D entities by projecting them onto the XY-plane of the current view.
Note: The PERSPECTIVE system variable must be set to 0.
Method
The entities will be projected onto the XY plane of the current view. In top view, the entities will be projected onto the XY-plane of the current coordinate system (WCS or UCS).
Entities before FLATTEN command:
Entities after FLATTEN command:
- Pyramid converted to a square with its diagonals.
- Cone becomes a circle with a point in the center.
- 3D polyline and spline are converted to 2D polylines.
Options within the command
- new ucs ELevation
- Specifies the new elevation for the resulting 2D entities.
- allow EXplode
- Explodes compounded entities, such as 3D solids.
