FLIPLINEEDIT command
Edits parametric flip operations.
Alias: PFLIPEDIT, PARAMETRICFLIPEDIT
Method
The command lets you edit an existing flip operation.
Enter the name of the desired flip operation, then select the parametric operation data to be edited.
Note: To dynamically edit a flip operation within a parametric block, select the block and click the flip operation's grip point.
Options within the command
- Selection
- Lets you edit the elements selection of the specified operation.
- Line
- Lets you define a new flip line by selecting its start and end points.
Note: All editing options can also be accessed from the operation's right-click context menu in the Parameters Manager and Mechanical Browser panels.
