FROM command
Allows you to enter relative coordinates with respect to a reference point whenever a command prompts you to enter a point.
Icon:
Note: From is a command modifier, not a command, and so it is entered only during a drawing or editing command.
Note: This command is useful for starting entities offset from another entity, such as inserting a door relative to the end of a wall.
Options within the command
- Base point
- Pick a point or enter coordinates to specify the base point.
- Offset or regular point
- Enter the offset by specifying relative coordinates, using the @x,y,z format
