GCCOINCIDENT command
Creates a coincident geometric constraint on 2D entities.
Icon:
Creates a coincident constraint to ensure a point on an entity remains coincident with a specified point or entity.
Methods
This command has 3 methods to begin creating a coincident constraint:
- Select first point
- Entity
- Autoconstrain
Options within the command
- Allows you to begin creating a coincident constraint by specifying a point on an entity.
- Select second point
- Specifies a point on an entity to make coincident with the first point. The point on the first entity maintains its position while the second entity adjusts, as necessary, to become coincident.
- Entity
- Allows you to begin creating a coincident constraint by selecting an entity.
- Select a point
- Specifies a point on an entity to make coincident with the first entity. The first entity maintains its position while the point on the second entity adjusts, as necessary, to become coincident.
- Multiple
- Creates multiple coincident constraints until you press Enter to end the command.
- Autoconstrain
- Creates coincident constraints by selecting all entities to which you want to apply relevant coincident constraints.
