GCCOLLINEAR command
Creates a collinear geometric constraint on 2D entities.
Icon:
Creates a collinear constraint to ensure two or more linear entities remain collinear.
Method
This command has 2 methods to begin creating a collinear constraint:
- Select first entity
- Multiple
Options within the command
- Allows you to begin creating a collinear constraint by selecting a linear entity.
- Select second entity
- Allows you to select a linear entity to make collinear to the first one. The first entity maintains its position while the second entity adjusts, as necessary, to become collinear.
- Multiple
- Creates multiple collinear constraints.
- Select entity to make collinear to the first
- Allows you to select a linear entity to make collinear to the first one. You can continue adding collinear constraints to other entities until you press Enter key to end the command. The first entity maintains its position while subsequent entities adjust, as necessary, to become collinear.
