GCFIX command
Creates a fixed geometric constraint on 2D entities.
Icon:
Creates a fixed constraint on a point or entity to maintain its position in the drawing.
Method
This command has 2 methods to create a fixed constraint:
- Select point
- Entity
Options within the command
- Select point
- Creates a fixed constraint by specifying a point on an entity. The point maintains its position while other geometry moves, as necessary, to maintain other constraints.
- Entity
- Creates a fixed constraint by selecting an entity. The entity maintains its position while other geometry moves, as necessary, to maintain other constraints.
