GCHORIZONTAL command
Creates a horizontal geometric constraint on 2D entities.
Icon:
Creates a horizontal constraint to ensure a linear entity or pair of points remains parallel to the x-axis.
Method
This command has 2 methods to begin creating a horizontal constraint:
- Select an entity
- 2 Points
Options within the command
- Select an entity
- Creates a horizontal constraint by selecting a linear entity to make parallel to the x-axis.
- 2Points
- Creates a horizontal constraint by specifying two points.
- Select first point
- Allows you to begin creating a horizontal constraint by specifying the first point to make parallel to the x-axis.
- Select second point
- Allows you to specify the second point to make horizontal to the x-axis. The first point maintains its position while the second point moves to become horizontal with the first point.
