GCPARALLEL command
Creates a parallel geometric constraint on 2D entities.
Icon:
Creates a parallel constraint to ensure linear entities remain parallel to each other.
Method
This command has 1 method to create a parallel constraint:
- Select first entity
Options within the command
- Select First Entity
- Allows you to begin creating a parallel constraint by selecting a linear entity.
- Select Second Entity
- Allows you to select a second linear entity to make parallel to the first. The first entity maintains its position while the second entity moves, as necessary, to become parallel to the first entity.
