GCPERPENDICULAR command
Creates a perpendicular geometric constraint on 2D entities.
Icon:
Creates a perpendicular constraint to ensure linear entities remain perpendicular to each other.
Method
This command has 1 method to begin creating a perpendicular constraint:
- Select first entity
Options within the command
- Select First Entity
- Allows you to begin creating a perpendicular constraint by selecting a linear entity.
- Select Second Entity
- Allows you to select a second linear entity to make perpendicular to the first. The first entity maintains its position while the second entity moves, as necessary, to become perpendicular to the first entity.
