GCSYMMETRIC command
Constrains a symmetric geometric constraint on 2D entities.
Icon:
Creates a symmetric constraint to ensure two entities remain symmetric with respect to a selected line.
Method
There are two methods to begin creating a symmetric constraint:
- Select first entity
- 2Points
Options within the command
- Allows you to begin creating a symmetric constraint by selecting a 2D entity.
- Select second entity
- Allows you to select an entity to make symmetric to the first entity.
- Select symmetry line
- Allows you to select a line to act as a mirror line between the two entities. The first entity maintains its position while the second entity adjusts, as necessary, to become symmetric about that line.
- 2Points
- Creates a symmetric constraint by selecting two valid points on a 2D entity.
