GEOMAPIMAGEUPDATE command
Updates a map image.
Updates the map image that was created with the GEOMAPIMAGE command.
Options within the command
Optimize
Optimises the map image.
Reload
Reloads the map image.
Related commands
  • GEOMAP command
  • GEOMAPIMAGE command
  • GEOMAPIMAGERESOLUTION command
  • GEOMAPIMAGETYPE command
  • GEOMAPKEY command
  • GEOMAPMODE command
Related variables
  • CURSORMODE system variable
  • CURSORSIZE system variable
