GEOMAPKEY command
Allows you to enter API keys to access online map services.
Opens the Online Maps Support dialog box, where you can enter API keys to access online map services.
Important:
- Bing Maps Key: Bing Maps are deprecated and can no longer be used in BricsCAD.
- Esri Maps Key: An Esri Maps key provides access to Esri online maps and can be generated at ArcGIS Location Platform.
For pricing information visit ArcGIS Location Platform pricing.
Each month, the first 2 million tiles are free, after which a charge of $0.15 per 1,000 tiles applies. If the 2 million tile limit is exceeded, the maps will cease to function until the user either enables the pay-as-you-go option within their ESRI dashboard or purchases a voucher.
Tip: To avoid exceeding the 2 million tile limit, it is advisable for each user to create their own ESRI account and API key. - OpenStreetMaps: It does not require an API key and is free to use.
Configuring the Esri Maps Key
Important: As procedures on the official website may change, you can also consult the official page (Tutorial: Create an API key with ArcGIS Location Platform) for the most up-to-date instructions if discrepancies are observed.
- Sign up for a free account at ArcGIS Location Platform. Click the Sign up for free button (1), then fill in all required information.
Note: Occasionally, Esri may block new sign-ups without a clear reason. If this happens, email accounts@esri.com to resolve the issue. - Once you have signed up, sign in, and on the , go to the Developer credentials tab, and select Manage developer credentials (2), which opens a new window.
- Choose New item (3).
- Select Developer credentials (4).
- Choose API key credentials (5) and click Next (6).
- Choose Private application with selected privileges and access (7) to use these credentials and click Next (8).
- Click No item access (9) if your token does not require item access. Then, click Next (10).
- Under Privileges, select Basemaps (11) and click Next (12).Note: Ensure that both Basemap styles service and Static basemap tiles are selected.
- Set an Expiration date (13) for the API key.Note: The default expiration date is 90 days from creation, but it can be extended to a maximum of one year. Once the current API key expires, you must generate a new one.
You can skip the Referrer URLs section (14), but make sure the field is empty.
Click Next (15).
- Enter a Title (16). The rest of the fields can be skipped. Click Next (17).
- In the Summary, ensure that the privileges include both Basemap styles service and Static basemap tiles (18). Click Next (19).
- Select Generate the API key now. I am ready to copy and save the key (20) and click Next (21).
- Copy the API key (22) and close the window.Note: Be sure to copy the API key and save it in a secure location, as it will not be stored on your Esri account.
- Go to BricsCAD and run the GEOMAPKEY command to open the Online Maps Support dialog box. Then, enter the API key in the Esri Key field (23) and click OK.
- Run the GEOMAP command and select an Esri map.
The Command line prompts:
Select map type [open street Map/Imagery/Streets/Light/Dark/Aerial/Road/Hybrid/Off] <Off>:
