GOTOSTART command
Displays the Start Tab.
Opens or activates the Start Tab.
Method
In the Start tab you can:
  • Open a recent drawing.
Note: The number of available recent files is controlled by the value of the RECENTFILES system variable.
  • Create a new drawing.
Note: Click on Template to choose what template is used when creating the new drawing.
  • Open a drawing using the Open file dialog box.
  • Access BricsCAD tutorials and sample drawings.
Note: Internet access is required.
  • Access the Third-Party Application catalog on the BricsCAD website.
