-HATCHEDIT command
Edits hatches via the Command line.
Method
Select an existing hatch or gradient entity to edit the options in the Command line.
Options within the command
DIsassociate
Removes the associative property of the selected hatch or gradient entity.
Style
Defines the behavior of the hatch when there are additional boundaries within a closed hatch boundary.
Nested
Applies alternating hatch patterns if a closed boundary contains additional boundaries, starting with the outermost boundary.
Outer
Applies the hatch pattern only to the outermost boundary, excluding nested interior boundaries.
Ignore
Applies the hatch pattern to the selected boundary, ignoring and hatching over any nested interior boundaries.
Properties
Allows you to specify a hatch pattern name, scale and angle, or to change the pattern to Solid fill, User defined or Gradient.
? to list patterns
Lists in the Prompt History window the names of predefined hatch patterns.
Solid fill
Changes the selected hatch or gradient entity pattern to a solid color fill.
User defined
Changes the hatch type to User defined. Set the hatch pattern angle for lines, space between standard pattern lines and cross-hatch area to customize the hatch.
Note: If a gradient is edited to a User defined type, it is automatically converted to a hatch. The gradient properties are not preserved.
Proceed
Applies your changes and closes the command.
Gradient
Changes the selected hatch into a gradient by entering a gradient pattern name in the Command line.
? to list patterns
Lists gradient patterns in the Command line.
Single color
Allows you to choose a gradient color and its shade or tint value.
Two color
Allows you to choose two gradient colors.
Truecolor
Defines the color by specifying the numeric values for the red, green, blue values in the Command line.
COlorbook
Defines the color by entering the name of an existing color book in your system.
Note: The COLORBOOKPATH system variable specifies the folder(s) in which BricsCAD® should look for color book files.
DRaw order
Assigns a display order to the selected hatch or gradient entity.
None
Removes the display order assigned to the selected hatch or gradient entity.
send to Back
Assigns the display order of the selected hatched or gradient entity behind all other overlapping entities.
bring to Front
Assigns the display order of the selected hatch or gradient entity in front of all other overlapping entities.
send beHind boundary
Assigns the display order of the selected hatch behind its boundary.
bring in front of bounDary
Assigns the display order of the selected hatch or gradient entity in front of its boundary.
ADd boundaries
Extends the hatch area by specifying an internal point within a boundary.
Select entities
Allows you to extend the hatch area by selecting an entity to use as boundary.
Remove boundaries
Reduces the hatch area by selecting a boundary-defining entity for removal.
recreate Boundary
Recreates the boundary of a hatch or gradient entity by specifying the boundary entity type, after which you can choose if the hatch is associated with the new boundary.
Region
Transforms the new boundary into a region entity.
Polyline
Transforms the new boundary into a polyline entity.
ASsociate
Associates the hatch or gradient entity to a selected boundary by specifying an internal point within it.
Select entities
Allows you to select an entity to use as boundary, instead of specifying an internal point within the boundary.
separate Hatches
Splits the selected hatch or gradient entity by creating individual hatch entities for each closed area.
Origin
Specifies a new value for the hatch or gradient entity origin by either entering point coordinates or selecting the point in the drawing.
ANnotative
Sets the annotative property for the hatch or gradient entity and applies the current annotative scale.
Note: The current annotative scale is defined by the CANNOSCALE system variable.
LAyer
Specifies the layer for the selected hatch or gradient entity. Either the current or a new specified layer can be chosen.
hatch COlor
Allows you to change the color of the hatch entity, starting with the color of the pattern and continuing with the color of the background.
Truecolor
COlorbook
. (for use current)
Applies the current color value as defined by the CECOLOR system variable.
Transparency
Allows you to change the transparency of the selected hatch or gradient entity.
0
Changes the transparency to the minimum value, making the hatch fully opaque.
90
Changes the transparency to the maximum value, giving the hatch maximum transparency.
Note: The transparency level is limited to a value of 90 to avoid confusion with layers that are frozen or turned off.
ByLayer
Changes the transparency to the transparency of the layer.
ByBlock
Changes the transparency to the transparency of the block.
. for use current
Applies the current transparency value as defined by the CETRANSPARENCY system variable.
Undo
Undoes the last action.
