INTERFERENCEMANAGERPANELCLOSE command
Closes the Interference Manager panel.
Closes the Interference Manager panel to hide it from the current workspace. If the Interference Manager panel is stacked when you close it, the Interference Manager tab or icon is removed from the stack.
Related commands
  • INTERFERE command
  • INTERFERENCEMANAGERPANELOPEN command
Related information
  • Add rule dialog box
  • Interference Manager panel
