INTERSECT command
Performs Boolean intersection operations on 3D solids and 2D regions.
Icon:
Alias: IN
Note: In the BricsCAD Lite license level, the command applies to region entities only.
Performs Boolean intersection operations on 3D solids and 2D regions by removing all except portions in common.
Note: If solids and regions do not intersect, BricsCAD erases them.
Method
Specify the 3D solids and/or 2D regions to be intersected. The program removes all except the volumes and areas in common from the selected entities.
The entities selected:
Result:
Note: You can interrupt the command by pressing the CANCEL button.
