-LAYOUTMERGE command (Express Tools)
Merges entities from specified layouts into a destination layout via Command line.
Options within the command
- Select Layouts to merge
- Allows you to specify the layout names to merge. You can type multiple layout names, separated by comma.
- Select Destination Layout
- Allows you to specify the name of the destination layout.Note: If the specified destination layout does not exist, the Command line prompt asks you if you want to create it.
- Remove empty layouts?
- Allows you to choose to delete empty layouts or not.
