-LMAN command (Express Tools)
Saves, edits and restores layer states via the Command line.
Options within the command
- Lists the available layer states.
- Import
- Opens the Import file name dialog box, which allows you to choose a LAY file to open.
- Export
- Opens the Export file name dialog box, which allows you to export the selected layer state to a LAY file format.
- Save
- Saves the current layer status.
- Restore
- Restores the layer settings of the mentioned layer state.
- Delete
- Deletes the mentioned layer state.
- reName
- Renames a saved layer status by specifying the old name and the new name.
