LIGHT command
Places light glyphs in drawings for generating more realistic renderings.
Icon:
Alias: LIGHTING
Note: Set DEFAULTLIGHTING system variable OFF to take into
consideration the active lights sources defined in the drawing. Otherwise, only
the default lighting will be used.
Options
- Point
- Creates a point light.Note: See the POINTLIGHT command for the meaning of its options.
- Spot
- Creates a spot light.
- Web
- Creates a web light.
- Distant
- Creates a distant light.
