MAPCONNECT command
MAPCONNECT command
Allows to set up a connection with a Web Map Service.
Displays the Map connect dialog box.
Note: Before adding map data to a drawing, you must run the GEOGRAPHICLOCATION command to define the geographic location of the drawing.
Related commands
  • GEOGRAPHICLOCATION command
  • IMAGE command
Related information
  • Map Connect dialog box
  • Geographic location dialog box
