MASSPROP command
Reports mathematical properties of 3D and 2D regions.
Reports the area, perimeter and other mathematical properties of 3D solid models and 2D region entities.
Note: All other entities are ignored by the program.
Note: You can stop the calculation by pressing ESC.
Options
- Write analysis to a file?
- Decides whether to save the report into a *.mpr file or not.Note: If Yes, the Create Mass and Area Properties File dialog box opens. The *.mpr file can be opened in any text editor. MPR is short for Mass Properties Report.
