MLEADEREDITEXT command
Edit leaders from multileader entities.
Adds and removes leader lines, adds and removes vertices, and changes the landing length of a multileader entity (short for "multiline leader edit extended").
Options within the command
- Add vertex
- Adds a vertex to the leader line.
- add vertex at ENd
- Adds a vertex and a new leader line at the arrowhead.
- Remove vertex
- Removes a vertex from the leader line.
- Stretch vertex
- Stretch a leader line by moving a vertex.
- add Leader
- Adds one or more leader lines to an existing mleader.
- rEmove Leader
- Removes a leader and associated vertex from the leader line.
- lengthen LAnding
- Changes the length of the landing.
