MOCORO command (Express Tools)
Moves, copies, rotates or scales entities.
Icon:
Method
Select the entities and specify a base point.
Options within the command
- Move
- Allows you to move the selected entities.
- Copy
- Allows you to make a copy of the selected entities.
- Rotate
- Allows you to rotate the selected entities around the specified base point.
- Scale
- Allows you to scale the entities.
- Base
- Allows you to select a new base point.
- Undo
- Undoes the last change.
