MOVEBAK command (Express Tools)
Sets the destination folder for backup files.
Icon:
Method
Specify a new folder name for all BAK files.
Note:
- Enter a . (dot) to clear the MOVEBAK folder name. New BAK files will be created in the original folder.
 - Type ~ to open the Select Folder dialog box, which allows you to select the MOVEBAK directory.
 - The creation of backup files is controlled by ISAVEBAK system variable.
