MPOLYGON command
Creates multi-sided polygon entities by selecting closed polylines, circles, or specifying points.
Method
Specify the start point, then create the mpolygon or select the entity to create the mpolygon.
Options within the command
- Specify start point
- Allows you to begin creating a mpolygon by specifying a start point.
- Arc
- Creates an arc.
- Direction
- Allows you to specify the tangent direction for the start point of arc.
- Line
- Creates a line.
- Undo
- Undoes the last line segment and allows you to specify a new point.
- Close
- Closes the mpolygon and allows you to start a new one.Note: Automatically draws a polyline arc segment from the end point of the last segment to the start point of the first segment, if the polyline is not closed.
- eXit
- Exits the command.
