MPOLYGON command
Creates multi-sided polygon entities by selecting closed polylines, circles, or specifying points.
Method
Specify the start point, then create the mpolygon or select the entity to create the mpolygon.
Options within the command
Specify start point
Allows you to begin creating a mpolygon by specifying a start point.
Arc
Creates an arc.
Direction
Allows you to specify the tangent direction for the start point of arc.
Line
Creates a line.
Undo
Undoes the last line segment and allows you to specify a new point.
Close
Closes the mpolygon and allows you to start a new one.
Note: Automatically draws a polyline arc segment from the end point of the last segment to the start point of the first segment, if the polyline is not closed.
eXit
Exits the command.
