MPOLYGONEDIT command
Edits mpolygons.
Method
Select the mpolygon you want to edit, then select the editing options.
Options within the command
- Add
- Adds new boundaries to the mpolygon selection.
- Delete
- Deletes the selected boundaries from the current mpolygon.
- Move
- Moves the selected boundaries from the current mpolygon. Select the base point and second point for the boundary displacement.
- disConnect
- Disconnects and deletes the selected boundaries from the current mpolygon.Note: The boundaries remains in the drawing as polyline or circle entities.
- Rebalance
- Rebalances the mpolygon to follow the nesting order (alternating outer/inner/outer order).Note: In BricsCAD, mpolygons are updated automatically to follow the nesting order. This option can be used in cases where this does not happen automatically.
- eXit
- Exits the command.
