NCOPY command (Express Tools)
Copies entities nested inside external references and blocks without having to explode or bind it.
Icon:
Method
- Select the nested entities you want to copy.
- Enter a base point.
- Enter a second point.
Options within the command
- Displacement
- Allows you to define a displacement vector instead of a second point.
- Mode
- Toggles between Single and Multiple.
- Multiple
- Allows you to make multiple copies.
- Array
- Asks for a number of copies and a distance.
