NEAREST command
Toggles the Nearest entity snap.
Icon:
Toggles the Nearest entity snap to enable or disable snapping to nearest. You can launch this command at the Command prompt to toggle a running entity snap. Doing so changes the value of the OSMODE system variable accordingly. You can also launch this command within another command to turn off the entity snap only for the current operation. This does not change the value of the OSMODE system variable.
