NONE command
Disables all 2D entity snaps.
Icon:
Disables all 2D entity snaps to prevent the cursor from snapping to 2D entities. You can launch this command at the Command line to turn off running entity snaps. Doing so changes the value of the OSMODE system variable to zero. You can also launch this command within another command to turn off entity snaps only for the current operation. This does not change the value of the OSMODE system variable.
This command displays no prompts and has no options.
