-OBJECTSCALE command
Adds or removes scale factors.
Adds or removes scale factors used with annotative entities through Annotation Entity Scale dialog box.
Note: Annotative scaling adjust scale factors of annotative items, such as text and hatch patterns, to match the plot scale.
Options within the command
- Select annotative entities
- Select one or more items using any selection method.
- Add
- Adds annotation scales to the selected annotative entities.
- Delete
- Deletes annotation scales from the selected annotative entities.
- Displays a list of available annotation scales as defines in the scale list.
